16-BitIndex
DT_INT-18 version 3.3 March 24, 2008
Available Interrupt Sources 16-bit
 INT0INT      ------INT0 External Interrupt
 INT1INT?      ------INT1 External Interrupt
 INT2INT?      ------INT2 External Interrupt
 INT3INT?      ------INT3 External Interrupt
 RBC_INT?      ------RB Port Change
 TMR0_INT?      ------TMR0 Overflow
 TMR1_INT?      ------TMR1 Overflow
 TMR2_INT?      ------TMR2 to PR2 Match
 TMR3_INT?      ------TMR3 Overflow
 TMR4_INT?      ------TMR4 Overflow
 TX_INT        ------USART Transmit
 TX1_INT      ------USART1 Transmit
 TX2_INT      ------USART2 Transmit
 RX_INT      ------USART Receive
 RX1_INT      ------USART1 Receive
 RX2_INT       ------USART2 Receive
 CMP_INT?      ------ Comparator
EE_INT? ------ EEPROM/FLASH Write Operation
BUS_INT? ------ Bus Collision
LVD_INT? ------ Low Voltage Detect
HLVD_INT? ------ High/Low Voltage Detect
PSP_INT? ------ Parallel Slave Port Read/Write
AD_INT? ------ A/D Converter
SSP_INT ------ Master Synchronous Serial Port
CCP1_INT? ------ CCP1 Interrupt
CCP2_INT? ------ CCP2 Interrupt
CCP3_INT? ------ CCP3 Interrupt
CCP4_INT? ------ CCP4 Interrupt
CCP5_INT? ------ CCP5 Interrupt
USB_INT? ------ USB Interrupt
OSC_INT? ------ Oscillator Fail
CMP0_INT? ------ Comparator 0 - 18F1230/1330
CMP1_INT? ------ Comparator 1
CMP2_INT? ------ Comparator 2
SPP_INT? ------ Streaming Parallel Port
BUS1_INT? ------ Bus 1 Collision
BUS2_INT? ------ Bus 2 Collision
ECCP1_INT? ------ ECCP1
LCD_INT? ------ LCD Driver
PMP_INT? ------ Parallel Master Port
SSP1_INT? ------ Synchronous Serial Port 1
SSP2_INT? ------ Synchronous Serial Port 2
TMR5_INT? ------ Timer 5
PT_INT ------ PWM Time Base
IC1IF_INT? ------ Motion Feedback
IC2QEIF_INT? ------ Motion Feedback
IC3DRIF_INT? ------ Motion Feedback
USB Module
 USB_INT?          ------ USB Interrupt (funnel)
USB_ACTV_INT? ------ Bus Activity Detect
USB_ERR_INT? ------ USB Error INT (funnel)
USB_RST_INT? ------ USB Reset
USB_IDLE_INT? ------ Idle Detect
USB_STALL_INT? ------ A STALL Handshake
USB_TRN_INT? ------ Transaction Complete
USB_SOF_INT? ------ START-OF-FRAME Token
USB ERROR Flags
 USB_BTO_INT?      ------ Bus Turnaround Time-out
USB_BTS_INT? ------ Bit Stuff Error
USB_CRC16_INT? ------ CRC16 Failure
USB_CRC5_INT? ------ CRC5 Host Error
USB_DFN8_INT? ------ Data Field Size Error
USB_PID_INT? ------ PID Check Failure
Ethernet Module
 ETH_INT?          ------ Ethernet Int (funnel)
ETH_DMA_INT? ------ DMA Interrupt
ETH_LINK_INT? ------ Link Status Change
ETH_PKT_INT? ------ Receive Packet Pending
ETH_RXER_INT? ------ Receive Error
ETH_TXER_INT? ------ Transmit Error
ETH_TX_INT? ------ Transmit
CAN Module
 CAN_ERR_INT?       ------ CAN bus Error
CAN_IRX_INT? ------ Invalid Received Message
CAN_RXB0_INT? ------ Receive Buffer 0
CAN_FIFOWM_INT? ------ FIFO Watermark
CAN_RXB1_INT? ------ Receive Buffer 1
CAN_RXBn_INT? ------ Any Receive Buffer
CAN_TXB0_INT? ------ Transmit Buffer 0
CAN_TXB1_INT? ------ Transmit Buffer 1
CAN_TXB2_INT? ------ Transmit Buffer 2
CAN_TXBn_INT? ------ Any Transmit Buffer
CAN_WAKE_INT? ------ CAN bus Activity Wake-up
Page last modified on February 14, 2018, at 12:01 PM
