CCP3_INT -- CCP3
Uses PIR3,CCP3IF, PIE3,CCP3IE Registers and Control Bits.
DT's Interrupts MUST be used with PicBasic Pro and MPASM.
The following block of instructions will establish the interrupt used and the PBP label (your ISR) to jump to once interrupt occurs. Remember; all PBP labels or variables used inside ASM code blocks must be preceded by the underscore,( _GetData). All instruction to the interrupt processor should be in ASM and preceded by the @ symbol and to the far left column of the editor if not included in other ASM code blocks.
Example:
@ INT_DISABLE CCP3_INT
INT_LIST macro ;IntSource Label, Type, ResetFlag?
INT_Handler CCP3_INT _GetData PBP Yes
INT_CREAT ;Creates the interrupt processor
INT_ENABLE CCP3_INT ;enables CCP3 interrupts
Command functions:
INT_CREATE ;Creates the interrupt processor
INT_ENABLE CCP3_INT – enable CCP3 interrupt.
INT_DISABLE CCP3_INT– disable CCP3 interrupt.
INT_CLEAR CCP3_INT – clear flags
INT_RETURN ---------- To restore and return to the program where interrupt was made.
Link to Microchip Tips & Tricks for CCP
<< CCP2_INT | 14-bit sources | CCP4_INT >>
